Travel2build
Aug 12, 2013Explorer
dougrainer wrote:Travel2build wrote:dougrainer wrote:holdn2aces wrote:
Doug, this unit is in a Jayco 30JTX, the reefer is not in the slide portion. I have investicated more and was going to try the suggestion you proposed next weekend when I get back to my trailer. I do not have an amp meter to test how many amps the heater is drawing but will try to get one for next weekend to confirm if the heater is within spec. Do the control boards go on these often?
Amp meter is not needed. The Heat element either works or it does NOT. So, if it gets hot it is working. Control board failure is not that common. Doug
It is warm when i feel the metal shroud around the heater. I know its always been warm but never actually felt it. Is warm enough?
If you hold your hand to the casing for more than 10 seconds, it should be hot enough to make you let go. Doug
Warm to touch after 1 day. Can hold my hand as long as I want about the viewing hole for the flame.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
