Travel2build
Aug 13, 2013Explorer
dougrainer wrote:
Then you need an amp meter 2.6 amps is spec. Doug
I don't think my meter checks amps. I have an ideal 61-310. I am not electrically educated. Never had a need. I could swap out any part and put anything back together. But knowing what is wrong electrically baffles me.
The fidge has been on 2 days now, still just warm at rear but inside is cold enough and freezer is frozen.
I am still skeptical. Why did it stop working 2 weeks ago. All I did was switch to propane, a week later check voltage on the heater terminals at board and left heater disconnected. Tried to check ohms but I am clueless what the numbers mean or if I did it right and it is within spec. Then 4 days later hooked the heater back up and tried it on electric and it seems to be working.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
