dougrainer
Aug 13, 2013Nomad
Travel2build wrote:dougrainer wrote:
Then you need an amp meter 2.6 amps is spec. Doug
I don't think my meter checks amps. I have an ideal 61-310. I am not electrically educated. Never had a need. I could swap out any part and put anything back together. But knowing what is wrong electrically baffles me.
The fidge has been on 2 days now, still just warm at rear but inside is cold enough and freezer is frozen.
I am still skeptical. Why did it stop working 2 weeks ago. All I did was switch to propane, a week later check voltage on the heater terminals at board and left heater disconnected. Tried to check ohms but I am clueless what the numbers mean or if I did it right and it is within spec. Then 4 days later hooked the heater back up and tried it on electric and it seems to be working.
Then your 120 element is working. BUT, the freezer should be BELOW 10 degrees and the refer below 40 degrees. Get those temp read outs and see if they are good. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
