holdn2aces's avatar
holdn2aces
Norcold N611 Fridge 5 flashes
Norcold N611 triggers trouble code 5 flashes, I reset it and 4-6 hrs later same code is displayed. I reflash the board and again it runs for 4-6 hrs code displays again. The freezer works very well,it can make ice cubes if I continue to reset it within resonable time. Is the board faulty or the controls, I am at a loss.
  • Doug, this unit is in a Jayco 30JTX, the reefer is not in the slide portion. I have investicated more and was going to try the suggestion you proposed next weekend when I get back to my trailer. I do not have an amp meter to test how many amps the heater is drawing but will try to get one for next weekend to confirm if the heater is within spec. Do the control boards go on these often?
  • Connect the 120 element to an extension cord and run for 24 hours. This bypasses the controls. IF it does not cool correctly, the Cooling Unit is bad. The NO CO (5 flashes) is a cooling unit protection. Is this refer in a slide room? Doug
  • holdn2aces wrote:
    I have leveled the trailer, do you think the cooling unit is faulty because after a reset it works very well, I can even make ice? I removed the roof vent cover and the vent is clear.
    Was it level before?
    Having it trip after 4-6 hrs.......resetting and then tripping again sounds like blockage. Unit turns on..begins cooling but due to blockage is finally reaching a point of no cooling detected so it trips.
    Off level operation causes a slow down in fluid to vapor to fluid and begins to crystallize which builds up.........effect is accumulative
    Vent is clear.......how about the air flow from lower vent across backside of cooling unit to roof vent.
    Any obstructions OR excessive gaps/areas (dead air spaces)?
  • I have leveled the trailer, do you think the cooling unit is faulty because after a reset it works very well, I can even make ice? I removed the roof vent cover and the vent is clear.
  • That is a 'no cooling detected' fault
    Means you have an ventilation obstruction, excessive off level operation OR the biggy.....cooling unit fail
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 22, 2025
