cavie
Jun 24, 2020Explorer
When in Gas mode the Auto switch must be OFF to run on Gas if you are plugged into shore power, the fridge will seek AC power if is available. Check your 120 breaker labeled Refrigerator. Even on AC the fridge uses 12 volts for control circuit and light. That's why you have yellow and green lights. Do you have power at the back side outlet?
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
