Shelborne's avatar
Shelborne
Norcold N621 now working after burping it
I had posted previously about my 2007 Norcold N621 refrigerator/freezer unit not working.
After sitting for about five years, I took it out on a trip and it worked fine for three days. Then, the following weekend it worked great for two days and then quit working on the third day.
I did everything I could think of to get it to work, including cleaning everything and trying it on AC...etc... do you know it just would not work, and there were no error codes or anything to indicate there was a problem. When I removed the vent from the outside, only about a foot of pipe got warm, and The remainder of it stayed cool, including the large ammonia dispenser.
I removed the refrigerator myself, let it sit upside down for about 18 hours, and turned it side to side temporarily, and banged on the pipes lightly with a rubber mallet.
Then I turned it right side up and let it sit for 10 hours.
I plugged it in last night before I went to bed, and came back to check on it, and after about 12 hours, The unit is working as it should....in fact I had to turn it down a little bit because it's too cold...I left it on the highest setting overnight.
Now all of the pipes are very warm/hot, and so is the ammonia dispenser. I hear a very slight gurgling if I really listen closely...so this indicates that things are moving inside the pipes....
I'm going to run it for a few days to just let it circulate.
Anyway, it was either this or buy a new refrigerator, or cooling unit, so I really had no choice.
I hope he continues to work, but so far so good!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
