Shelborne
May 17, 2017Explorer
Thank you very much for your comment Doug!
Yes, only time will tell if it will continue to work or not.
I did have the unit off for several hours on my last trip, when it wasn't working and going through mountains and valleys. Nothing changed.
The bottom most pipe got warm about a foot out, and as it made the upward turn, it was cold from there on upward. The ammonia dispenser remained cool as well. There weren't any sounds of circulation.....
After I did the burping, I now can hear it circulating as it should, and the pipes fluctuate from being warm to cool as the unit cycles.
I had to turn the unit down from 9 to 5 because it was getting too cold, likely because there's no food in there.
I'm going to run the unit for a few days, just to keep it circulating.
The RV was parked for over five years and the Norcold was never turned on.... this might have something to do with it, although the first trip we took after it was parked it worked fine. We slept at a spot that was unlevel, and I wasn't using my head. It was very late, and dark, and I hadn't camped in five years, and I didn't remember the refrigerator needed to be level or risk damage. I thought that it wouldn't operate if it was too much out of level, that it would shut off. I definitely won't make that mistake ever again!
I always got my unit level in the past with Lynx levelers.. etc..., but that particular night I was very tired and didn't think much of it. It worked perfectly on the first trip, when it was operated off level, it was during the second trip that it quit after two days, when it was level. I now realize that a lot of the stuff is cumulative, and weird things can happen when the unit is off level, including frying the unit. I did hit a large pot hole with the trailer that caused things to go a bit berserk but I don't know if that was related or not. Probably not.
I'm going to keep my fingers crossed, and hopefully the Norcold unit will continue to work as it should.
As I mentioned before, only the freezer got a little bit cold, it look like it was trying to work but something was blocking it.
I'll keep you all posted on what happens. You guys are great, and have super information thank you all!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
