dougrainer
Jan 18, 2021Nomad
Norcolds built in the past 2 or 3 years have a problem with BAD logic in the rear control boards. ALL different types of failures and problems. You need to have it checked out at a Norcold Service center. Hopefully you are under Norcold's warranty. Once the Tech checks out the Norcold and talks to Norcold, odds are Norcold will send a replacement Board. Doug
Norcold warranty is 2 years.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
