First off.......
Bypassing the circuit bd and running fridge DIRECTLY on element with a 30.4*F temp MEANS cooling unit IS functioning
Bypassing circuit bd and fridge functioning means circuit bd is problem OR thermistor is bad
Unplug thermistor from circuit bd.....fridge goes in Back Up Operation....TEMP button controls cooling cycles.....1/short cycle 9/longest cycle
Run fridge over night with everything normal except for the unplugged thermistor. Use 9 temp setting
Fridge cold....thermistor is bad
Fridge doesn't stay cold..circuit bd problem
