ksg5000
Jun 11, 2013Explorer II
Take off the exterior access panel - if the vent tube is hot and the fridge is warm then you have blockage issue and burping may provide temporary help. If vent tube is cold then it's not blockage.
Have you checked the fuses located on the circuit board - board is located under plastic cover which can be accessed when you remove exterior access panel.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
