fidhleir wrote:
We arrived in camp and connected to shore power. The fridge switched from Auto LP to Auto AC as it should. About an hour later we noticed the display was off and no light inside. The fridge won't start. Checked the fuse. It's not blown but when I pulled it, the indicator LED didn't come on so I'm assuming there's no 12V. We have about $200 worth of food that we're going to lose tonight unless someone can help. I don't know where else to look. I'll call in the morning but by then the food will be gone.
Low voltage will do that also.
Check out put of converter
Check out put of your coach battery
Have you used your air cond lately? It will come on ok but when it reaches the temp set on thermostat and shuts off, it will not come back on again.
There's your proof the converter is not charging or over charging your coach battery. Resulting in both ac and fridge not having the correct 12v they need for their thermostats. Been there done that.:(
