path1 wrote:
Any chance recall fix put a hole in pipe? The next day I found out that the pipe where they put the sensor leak
I would be talking to the folks that installed the clamp if pipe is leaking from where they "fixed" it.
We had a A/C gasket replaced by our rv dealer. He sent out his grandson who in the process of fixing A/C gasket walked on and broke our skylight. Next day Grandpa was out there fixing what grandkid messed up.
You don't understand the issue- the clamp is only holding a sensor against the tubing. There is absolutely no way it could cause a leak.
