Casinojunkie
Nov 24, 2015Explorer
Old-Biscuit wrote:
Fridge electric element
Fridge plugs into 110V outlet.......that AC power is for electric element. That's it, nothing else uses the AC power
AC power goes to control module thru power cord then thru 5A slow burn glass fuse on board then to element
GFCI trips due to shorted element
Aren't you getting any 'fault' codes?
'A' 'P'
30W Heating element Norcold 621702
$36 - $39
Thank you for the information. I am getting no fault codes.
Would I get fault codes if I shut off the propane and demanded 110V only?
Is that 5A slow burn glass fuse on the control board on frig.
Just trying to do the least expensive way.
Where is that heating element located and how to change it?
Thanks
