ScottG
Apr 23, 2023Nomad
C Schomer wrote:
Id checked the gas pressure too. If the pressure is low, the btu input will also be low but it will also draw in less primary air. A dust free, clean orifice is also important, but that doesn’t sound like it would be a problem in your case. Be sure the burner is super clean, so nothing restricts the primary air intake.
If it still soots after all that cleaning Id figure out a way to get more primary air… by hook or by crook, there are ways. Craig
Good idea. I had suspicions about my pressure so I built a manometer and found that my reg not only wasn't regulating, it would drop to 10" with more than one appliance running - the the reg was only 4 y/o!
A new American made regulator has everything running perfectly.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
