dougrainer
Apr 23, 2023Nomad
KenS999 wrote:
"Make sure your flame is not yellow, lastly adjust your flame fuel screw if everything else is clear."
Thanks. Flame is blue. Where is this fuel screw that you mentioned located at? Burner tube/orifice is a single piece, and brand new. Ken
There is no fuel adjustment screw. I would remove the orifice and make sure it is not partially blocked. I would blow compressed air UP the burner tube to clean it out. If the refer is in a slide room you can remove the burner baffle from the upper vent door. Otherwise you will have to pull the refer to verify Burner baffle and no debris. An EASY check of a regulator without a Manometer is to light the range burners(all 3 or 4). Then run the water heater on LP and the Furnace. IF the range burner flames rapidly pulsate up and down or diminish, your regulator is BAD. Replace it. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
