dougrainer
May 12, 2020Nomad
The normal test for your type problem is to take paper clips and see if they ALL stick to the main cabinet frame where the seal touches. You install paper clips around the complete frame to see if there is a fault in interior magnets(Clips fail to hold in place at spots). If so, take a pic and Norcold will probably replace the refer. You will have to go to a Norcold service center for verification of your test. IF this is not the case then replacing the door is next. Doug
