Ed_Gee
May 12, 2020Explorer II
dougrainer wrote:
The normal test for your type problem is to take paper clips and see if they ALL stick to the main cabinet frame where the seal touches. You install paper clips around the complete frame to see if there is a fault in interior magnets(Clips fail to hold in place at spots). If so, take a pic and Norcold will probably replace the refer. You will have to go to a Norcold service center for verification of your test. IF this is not the case then replacing the door is next. Doug
Per my original post, the door IS held tight....it is the rubber gasket that is pulling back from tight fit.....but only about 18" of it. Email is pending with Norcold. Yes, I expect a door replacement is the only suggestion I'll receive from them....
