Old-Biscuit wrote:
pbitschura wrote:
pbitschura wrote:
enblethen wrote:
You say gas supply not an issue, how was that determined?
I would replace the regulator on the tank. Make sure you get one that faces the vent down.
Full tank, on board. All other gas appliances, stove, oven, work fine, and for now, the frig.
New fuel. All else work fine. Igniter fine. Problem must be in the fuel delivery. If burner is dirty then why is failure to light rare and extremely intermittent?
Because the igniter is not properly positioned over burner slots, igniter gap is not correct, burner slots are obstructed and/or gas flow is obstructed
Clean burner assembly....not just blow air thru with a straw
I will clean the entire assembly. Igniter gap? a long stick match would not light the burner either. Did I mention, it's working fine now and has for 48 hours. Did I also mention the same problem ocurred a year ago and not since until a few days ago? I appreciate all suggestions.
