dougrainer
Mar 13, 2017Nomad
Odds are it is one of the rear 12 volt cooling fans. These fans are on the backside of the refer and unless the refer is in a slide room, you have to pull the refer to verify and fix the fan problem. But the fact you state it clicks in the OFF position means that in OFF there is no power to those 2 fans. Are you POSITIVE it is the refer making the noise and not something else next to it? You need to disconnect the 12 volt power wire on the backside of the refer, instead of disconnecting the Batteries. Disconnect the 12 volt to the refer and see if the noise goes away. Doug
