Old-Biscuit
May 26, 2015Explorer III
Fridge uses 12V DC.......control circuit, propane etc.
DO you have 12V DC (+/-) at control board (12VDC & GND1)
No 12V then problem is at DC Dist Panel (fuse) or wiring from panel to fridge
Got 12V......
Check 12V DC to/thru 5A DC Fuse (Tan....auto type blade fuse)
No 12V....is fuse blown, are fuse holders tight
Got 12V....
then need to check for 12V at upper panel (optical board)
Remove upper panel and unplug connector
Then check for 12V DC between White/Violet and White/Red wires
12 pin connector
top row.....far left pin *white/violet
top row.....right side second pin in *white/red
Got 12V......
then optical board is bad
No 12V...
then control board is bad
Got 12V......
Got 12V....
12 pin connector
Got 12V......
No 12V...
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
