dougrainer
May 30, 2015Nomad
Have you ACTUALLY checked the 12 volt voltage at the refer with a Voltmeter? There will be NO power to any solenoids (gas valve) if the refer does not even power up or show display. ON the burner casing is a hi limit switch. Have you checked the voltage in and out of it? If it trips there will be no power to the refer at all and the controls will be dead. Doug
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
