dougrainer
Jul 17, 2012Nomad
The odds are you are NOT cooling in AC mode. That means your AC 120 element is NOT operating. 2 things that will cause that.
1. The AC element is defective
2. The 5 amp fuse for the 120 element on the control board is blown. IF that fuse blows, then you need to replace the 120 element as it is causing the problem (fuse blowing). Doug
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
