- larry_cadExplorer IICongratulations!
- We removed a 18cf Norcold and installed a 20cf Whirlpool thru the door of out 5th wheel Solitude.
- pianotunaNomad IIIThanks for letting us know!
- Grey_MountainExplorerOld fridge out, replacement in. Through the door. Fairly easy job.
Installed a Magic Chef 10.1, $499.
Thanks for all the tips.
GM - larry_cadExplorer II
Grey Mountain wrote:
allbrandauto wrote:
my norcold 1200 went through door of 24 and a half inches by removing norcold front doors installed samsung the same way
I will also consider that option.
Thanks.
GM
This should work, if you remove the frig doors, and maybe the RV screen door. That worked for mine when I did it. - Grey_MountainExplorer
Thanks.
GM - allbrandautoExplorermy norcold 1200 went through door of 24 and a half inches by removing norcold front doors installed samsung the same way
- Grey_MountainExplorerI have a tractor with a front end loader. Looks like through the window is the route to go.
Thanks for the information.
Getting ready to seel the rig.
GM - craig7hNomad IIHave you thought about just replacing the cooling unit? I replaced my norcold cooling unit two years ago with a totally 110v system works great. You may want to look into JC Refrigeration products. Its really an easy DIY process. https://jc-refrigeration.com/
Its not getting the old one out but the new one in. A lot of folks have done it so hopefully one of those will help.
Good Luck - Grey_MountainExplorerLooks like out the window is the way to go.
GM
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
