RobWNY wrote:
It's a Norcold N611 unit. There isn't any adjustment knob to make it colder or warmer. Must be the basic Norcold Refrigerator.
Yes, there is. On the front control panel you either have a switch or slider that goes from 1 to 5. Norcold does NOT make auto temp adjust refers. I read the install for the Clip and snip for the Norcold. It is nonsense. The replacement Thermister for Norcolds does NOT have excess wire. It just clips to the 4 wire connector by the interior light. It connects both to the light bulb spades and then to the 4 wire quick connect and you clip the sensor on the evap fin. WHY anybody would use the Clip system on a refer that has an adjustable tstat is beyond me. IMO, the clip system sends an OHM feedback to the rear control board. BUT, since that OHM reading is sent by the NEW Clip sensor, it must then navigate to the rear board that is looking for a specific OHM reading and wants to analyze a signal that is NOT correct. Last, Norcold makes different Thermisters for their various models. You must install the Thermister for your soecific model. LONG shot would be the Wire from the evap area is OPEN between the thermistor and the control board, but I have never seen that in 30 years. Doug
