craig7h
Jun 18, 2021Nomad II
From what is posted it looks like your frig is dead. If so at this point you have some decisions to make. Replace with new Norcold, replace with residential frig., or just replace the cooling unit.
My thoughts as I went through the same process. We ended up going with replacing the cooling unit. Reason, easier cheaper DW and I could do it.
I went to JC Refrigeration and with their help got the correct cooling unit. I went with the 120v only as we are always plugged in and never boondock. That made more sense to us. It really is a take out the old and put in the new. Check them out as part of your decision process.
https://jc-refrigeration.com/
Good Luck safe travels
