Chris Bryant wrote:
I wouldn't rule out the thermistor unless you tested it while the refrigerator was misbehaving- an intermittent problem means, by definition, the parts will test good sometimes.
A defective thermistor will still test good thru all parameters. Soooo, the cheaper way is to just replace the Thermister when you have this type problem. I doubt the Circuit Board is the problem on a problem like this. People ALWAYS seem to think the Control boards are the problem. As someone who works on these RV's and have for 35 years, in the past 15 years, the OEM control boards rarely fail. Doug
