MrWizard
Apr 14, 2016Moderator
It is possible to do All kinds of wiring contortions
That does not mean you are going to get correct readings
If you attach to the controller output, you will read controller voltage not battery voltage at the shunt
What ever the voltage drop between controller and battery shunt is , Will alter the Watts display and voltage value displayed
But if the wire is short and thick, the differences could be small enough to not mean much
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
