JRRNeiklot
Feb 05, 2017Explorer
Trimetric 2030 battery monitor
I'm in the process of installing my solar setup.  I have everything installed except the solar panels.  I am having issues with my Trimetric 2030 battery monitor.  After charging to 95%, according to my battery charger, it's showing 14.5 volts, both at the charger and the Trimetric, but the amps are showing negative .3, which is the draw of phantom loads, I assume.  It shows the same -.3 when I'm not charging.  It should be showing the amount of amps incoming, correct?  I discharged the batteries to 12.3 volts today - my battery charger was showing 62%, but the Trimetric shows the battery perentage at 98%. Can anyone help me straighten this out?
Thanks.
Thanks.
