BFL13
Oct 03, 2016Explorer II
I understand the question, but another factor is how much 6s gas, especially older ones like mine (5 years)
I found in summer on solar with long sunny days in a row and set to 14.8, that the batts got to 14.8 mid-day so that left a long time still to go in daylight at 14.8 while amps tapered. I was losing "water" more than I liked, so I dropped to 13.6 soon after reaching 14.8.
The batts still got to full that day as measured by hydrometer, but did not lose nearly so much water per week.
A side note-- my old rule was they were at 90% SOC when amps had tapered to 5 amps per battery at 14.4/5 volts. When I increased charging with 14.8v, the amps per battery at 90% was more, but I didn't have a measurement. I have enough evidence now to use 8 amps per battery as my new "marker" for when to stop the gen at estimated 90% SOC instead of 5.
Essentially that means the taper curve is steeper with 14.8 getting to full but by the time you are at 98% or so nearing 100, the amps will be so low the amps difference will be small between 14.4 and 14.8 by then.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
