Kirk
Oct 16, 2013Explorer
It sounds like your Surge Guard is probably doing the right thing and has removed power due to some type of fault. Should voltage drop below or go above safe levels it will remove power until the voltage returns to normal. There has to be some sort of power problem or the circuit breaker would not have been tripping. Have you checked for proper voltages with a good digital meeter?
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
