enblethen
Dec 11, 2013Nomad
First check the power receptacle for power. What type of source are you connecting to?
If you are using an adapter, try a different one.
Your transfer switch may have failed. Locate it and check for power coming in on the shore power side.
What happens when you start the genset? If power is good you have isolated the problem to shore power. Could be no power at pedestal, bad adpater if used, transfer switch.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
