TakeNothin4Gran's avatar
Jan 17, 2014
Not sure if I need a new converter or.............
I have a Springdale TT with a Dometic fridge and the standard WFCO 3 stg converter. It's hooked up to the house so there's power in it.
Here are my Springdale's symptoms:
The refrigerator decided last week to shut down. But, it will will turn on if the M/W is being used or if I turn the hot water heater breaker on. Sometimes it will stay on for a day or so and sometimes it's stubborn and will turn off within a couple hours.
Now, when the fridge turns off, it doesn't kick it's breaker off. No breaker within the WFCO unit has ever kicked off. I just keep the water heater off since we don't use it so no need to pay the extra $$$.
Also, when it's on, the fridge works just fine. Keeps everything cold/frozen no problem. I've never used LP with it and actually gave my son the large tanks to use for his bbq & outdoor heater so I don't have them currently.
What do you guys/gals think my best course of action should be? Is there a way to just switch out the actual fuse part for the fridge or should I replace the whole unit or .........
Thanks for your expertise!!
Moved to Tech Issues forum from DIY.
  • I would check the 120 volt shore power connections.
    If you are using an adapter, check for heat build up and discoloration on the pins.
    I would take a little time and check connections in the 120 volt power distribution panel. Pay special attention to the neutral (white wires) in the rear of the panel. Look for any metlted insulation. I would suggest getting some electrical grease and re-terminate the conductors with a liberal amount og electrical grease.
  • I think I would try it on LP first, maybe that will narrow it down. I had one that worked on LP and not at all on electric and turned out to be in the on/0ff switch.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
