- MEXICOWANDERERExplorerThe Triplett was a great meter until the hurricane got to it. <1% error at 200 amperes DC. I had issues with the 9-volt battery dying yearly, but now that I have lithium 9 volt batteries that may be a thing of the past.
I want a meter that speaks. Shouts actually. "FOURTEEN POINT THREE FOUR VOLTS DC!" May get a little hairy with voltage changes though... - MNtundraRetNavigatorI would not trust either without being able to download a manual to get real information on accuracy for ranges used by the meters.
My Sears unit came with all the needed information to make an intelligent decision. It also does more than either model shown. - JiminDenverExplorer IIYa know, they have lasers that will remove tattoos now. ;)
- Dakota98ExplorerOn Amazon, discontinued, not available. Two reviews since December 2012. Wasn't selling --- Rebranded.
Triplett #9310-a
On Amazon - Rebranded under Elenco
Elenco #ST3030 - BB_TXNomadFrom the pictures there is some small difference between the two on either side of the clamp along the rib. Whether that difference relates to something worth nearly double the price is not obvious.
And yes, you do pay more for a "brand name".
Edit: after looking at blown up pictures of each the difference in appearance is only due to different angles. - chevorExplorerNever heard of either.
- MNtundraRetNavigatorWhile the clamp-on meter picture looks the same, did the specifications for each read out the same?
You did not mention specifications for: range, accuracy, etc. The circuitry inside may be less quality. - MEXICOWANDERERExplorer"Nnnnaaant Zooot" is a great brand name for electrical stuff.
I paid 113 dollars for the Triplett. After I found what the Triplett REALLY was I saw this reflection in the mirror. - aruba5erExplorerWell, it does cost something to have your name put on it. A couple of cents per unit. If you wanted to market that meter, the manufactuer could put your name on it too. Wanderer sounds like a Good Brand. Ain't that something. Like they say "Buyer beware"
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
