Fosters's avatar
Fosters
NOW..........NO HOT WATER AT ALL!!!
Re: Suburban WH type
2nd owner to my 5th that has dual HW heating and not a single piece of repair history before I bought it in June 2016. Anyhow, I got hot water both by LP and elect with no problem till now, Jan 2017.
I prefer to use Electric mostly, and suddenly no hot water. Switched to LP and firing hot water, no problem. But I had to of course, find out why the elect was not working any longer. I am a DIY'r as best as I can. So with Dr. Google and youtube I tried to self teach myself on the use of a multi meter. I found the resistance only @ .10 for the heating element, which online mechanics tell me "that it is good". Anything higher then like .20 they say is bad.
So next is the thermostats, and visually both look. Meaning no obvious burnt outs or disconnects in either of the 4 fasteners. And I am aware, that the lt blue 2 on the LF are elect and the pink 2 on the
RT are gas. What should the resistance be on the thermos?
So I went ahead (before the meter check) and bought a replacement heater element and anode rod as well. I replaced the anode rod and glad I did (for assuming the original was still installed, now 8 years later and very well sacrificed for the job intended!). But I could not get the heating element out as I do not have a 1 1/2" socket. But again, the meter test indicates that is not the problem anyhow. But I want to check "how eaten up" it is anyway (have the replace part as well)?
What am I missing?
And get this, and salt in the wound, I put everything back together and NOW I CAN'T EVEN GET HOT WATER WITH THE LP SOURCE!!! Forget about the electric for a 2nd. The LP gas channels thru the pipe all the way to the what is it called "thermocoupler" (the part with the 2 prong arms that hang over the pipe) and ignites it right? Well, she flames up for 5 secs and shuts down. Then, repeats 2 more times (as I have also read, a total of 3 times try). So why won't the LP gas stay lit and heat up the water tank? And yes, full tank of LP and full strength of LP flow.
Please help, for now I have no HOT Water either LP or Electric!
Thanks in Advance and I hope I can answer questions to repair the problem or problems.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Nov 30, 2025
