Derick's avatar
Derick
Odd 7 pin wiring harness
Hi all - this isn't actually RV related, but it is trailer related. I purchased a flatbed from a co-worker over the weekend and I had to re-wire the 7 blade connector since it had been driven over (or something). I was able to get things working, but I wanted to run this by anyone who would know.
I have the following wires;
Yellow - Left Turn
Red - Trailer Brake
Black - Ground???
Blue - ???
Green - Right Turn
Brown - Tail/running lights
There are two things that are strange right out of the gate. First, no white/ground wire. I have black wired into ground right now, and while I dont think it would be anything else, I haven't yet verified that (ie, remove it, and see if everything fails). The other is that the trailer brake is on red...when everything says it should be on blue. The brakes indeed work, and it's recognized by the controller...but very strange. Right now, I have the blue wire not connected to anything, but I believe its the aux/charging circuit for the breakaway battery. Still need to verify that too.
That said, is there any sort of "other standard" out there that would explain, or at least validate what I've found so far?
  • Yes, I can google, I know what they SHOULD be.....this is a thread on what they actually are.
  • Once the wires are sorted out for which pin is which, it remains there needs to be a way to keep the trailer's breakaway battery (mentioned in the OP it has one) charged up while the trailer is parked. IMO also do a test of that system by pulling the pin and see if it works (but not when the 7-pin is connected since that can fry the controller in the truck ISTR)
  • ScottG wrote:
    Blue is supposed to be the backup light circuit.
    Blue is brakes and trailers rarely have backup lights because they would serve little purpose. I'm sure OP could find a wiring diagram as easily as any of us, the question was is the setup he has of any standard.
  • Its a 1999, and anything is possible that it was re-wired. However, based on the discussion with the owner it was rarely used, so while certainly possible - it seems unlikely.
  • How old is it? From having trailers for 20+ years and my own experience I would guess that it's been rewired at some point. How old is it?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
