TReiner's avatar
TReiner
Odd electrical issue
First off thanks in advance for the forum, hoping you guys can help me out.
I have a issue with power from the generators, powering my Lance Camper.
Panel works, charges etc, The ac, micro etc all run fine off shore power, but when I run via the on-board or either of my Honda EU generators the power "trips" and goes off.
I was told it was likely the power converter, just spent an hour swapping that out to still have the same problem.
TIA, Tom
  • BaddogLT wrote:
    What size EUs and is this a new issue?
    My recent research showed 2000 watts would not be enough for my AC - especially at altitude.
    True, I tried with a 1000 and a 3000, not even trying to run the AC, this still happens when all the breakers are off too
  • A1B00902 wrote:
    It could be the transfer switch
    That switches from shore to genny not the converter
    Where would I locate that on the camper,,?
  • It could be the transfer switch
  • What size EUs and is this a new issue?
  • More information will help people in figuring out the issue. What size generators are you trying? What all are you trying to power with the generator?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
