N-TroubleExplorerAug 25, 2019Odd tire wearWhat would cause this odd wear on only the outer tread blocks? Inner tread blocks are smooth/round. These are the only two tires on the trailer that show this type of wear.
2oldmanExplorer IIAug 26, 2019Carlisle tires.DutchmenSportExplorerAug 26, 2019Out of balance AND under inflated. It's a combination of both:Here.It is a combination of under inflation and cupping.Cupping is caused by being out of balance (or) a result of bad shocks, bad struts. Read here. This explains a lot more.N-TroubleExplorerAug 26, 2019They are the same tire brand/size.time2rollNomadAug 26, 2019I read mismatched pressure or diameter.BusdriverExplorer IIAug 26, 2019Maybe out of balance12th_Man_FanExplorerAug 26, 2019Low air pressure!
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 14, 2025
