N-TroubleExplorerAug 25, 2019Odd tire wearWhat would cause this odd wear on only the outer tread blocks? Inner tread blocks are smooth/round. These are the only two tires on the trailer that show this type of wear.
16 RepliesReplies sorted by NewestShow More2oldmanExplorer IIAug 25, 2019Carlisle tires.DutchmenSportExplorerAug 25, 2019Out of balance AND under inflated. It's a combination of both:Here.It is a combination of under inflation and cupping.Cupping is caused by being out of balance (or) a result of bad shocks, bad struts. Read here. This explains a lot more.N-TroubleExplorerAug 25, 2019They are the same tire brand/size.time2rollNomadAug 25, 2019I read mismatched pressure or diameter.BusdriverExplorer IIAug 25, 2019Maybe out of balance12th_Man_FanExplorerAug 25, 2019Low air pressure!
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
