fred42's avatar
fred42
Oddly wired Distribution Panel
On my last trip, the converter failed and I had to use a portable battery charger to keep up my coach battery. Back at home, I removed the distribution panel to get to the bad converter. It was a WFCO 55amp, I plan to put in a Progressive Dynamics PD9260C.
I see that the wiring diagram shows the two 50amp legs of my power going to separate buses as you would expect.
The odd thing is that I apparently am not using any of the black leg power and this coach has two ACs, electric water heater, and microwave. On my last trip on arrival I was blowing the park 50amp breaker. Never had this happen before, but the park changed their breaker and it was OK. Maybe this setup pushes the limit of one leg of the breaker. Another odd thing is that you would expect the DC converter to be on its own 15amp breaker, but this one has the converter and two house circuits nutted into a single breaker (rightmost 15amp breaker). That poor little piece of 14 gauge wire must get warm at times.
If this seems odd to you as well, I may purchase another breaker and put it on the left black leg bus and then put just the converter on it.
thanks for any ideas,
Fred
