Hammerboy's avatar
Hammerboy
Off grid power 101
Hey all
Long time rv'er but never but never a dry camper. As time goes on the more I want to try or even get into it more but first I would need to set up the fifth wheel do so. I understand the concept of conserving power, water, etc.
My question is what would be your priority list be and in terms of importance? What are the costs of each item? If you gave your self a $500 starter budget what would it be? Would I need more $$?
When it comes to batteries, solar, electrical, I am limited in knowledge in this area. I hear things like needing to upgrade your converter, getting a good battery moniter, etc and those are things I wouldn't have thought about. Aside from needing a generator I'm assuming the first baby step would be to upgrade my cheap stock 12v battery to a pair of 6vs?
Thanks in advance for your knowlege
Dan
  • 1) Do some learning on AC & DC electrical systems and how power is measured.
    2) Do an assessment of your current power usage.
    3) Figure out what you could live without from your current power usage.
    4) Calculate the remaining power needs.
    Do this before buying anything.
    - If you are a minimalist camping on moderate weather, you may not need to do anything to dry camp.
    - If you aren't willing to give up creature comforts, a solar system and other purchases may be a waste of money as they won't meet your needs and you will have to buy a big generator.
    - Most likely you will fall somewhere in between.
    If someone tells you to buy X, given what you have told us, run away from the advice as they have no clue what you need.
  • I don't do a lot of dry camping but I do go to concerts and dry camp for several days at a time. My camper came with a genny and with the OEM 12v battery and careful battery use I am able to go for a couple of days before I recharge the battery. I did however replace the OEM fixed voltage battery charger with a good 3 stage charger for more rapid charging.
    Oh Yes, I also installed a 12v voltmeter and ammeter to monitor my battery use.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
