rockhillmanor
Nov 11, 2013Explorer II
Sounds like you got the keep warm inside covered. But your water lines will freeze. Many MH's the "heated tanks" are nothing more than splitting the heater vent in the back bedroom in half and sending that heat down to the sewage bay.:R
For the DW:
Get a porta-pottie. That's what I used on the way down south when I had to leave with a winterized MH. I don't do gas stations when traveling!
The toilet is 'exactly' like the one in your RV. You can buy them with different size tanks. Depending on how long your stay is. Then dump it at a gas station toilet or dump station.
The holding tank cassette underneath has a real slick swing tube for easy dumping into a gas station toilet or CG dump station. Clean, absolutely no smell. And fits the bum just like your RV toilet.
You can pick up the average size tank one at any Walmart for 60 bucks.
Here's the link for all the models from Thetford.
http://www.thetford.com/HOME/ApplicationHome/RecreationalApplication/tabid/85/Default.aspx
For the DW:
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
