Bill_Satellite
Nov 11, 2013Explorer II
If you want to be able to keep your holding tanks full and usable then the water lines are going to burst if you do not use the coach heating system as that will be the only thing that blows warm are into the wet bays. My understanding is that not all coaches are setup for this option so you will also need to verify that you coach is. Without that option, dry camping in very cold temps would require that you winterize the entire water system and use bottled water, portable toilets and take no showers.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
