Waitin2Retire's avatar
Feb 06, 2021
Oil in Propane
Hey All,
I'm trying to determine how to troubleshoot/correct my propane issue safely. This is on a 1998 Roadtrek 170 Popular on Dodge chassis.
I was smelling propane and saw the hose from tank to regulator was dry rotted. I replaced the hose and regulator. The old regulator was dripping oil when I removed it. I didn't think to check for more oil in the lines or the tank. Is there a safe way to empty the propane tank and flush the tank and lines to the appliances?
Thanks in Advance!
Greg
  • If your rig has ever been to southern Mexico particularly near the coast and been refilled there by a mobile Propane/ Gaz truck it has been filled with a mixture of Butane and Propane!
    There will be a small amount of oil present especially if the tank wasn’t used a great deal on the trip back north! This oil condenses or thickens with cold temperature!
    The best cure that I have found is to wait for warmer weather or fill the Tank with fresh locally brewed Propane at home as soon as I return .
    I don’t refill in Mexico on the trip home or just prior to that trip !
  • 3_tons's avatar
    3_tons
    Explorer III
    You should make no assumptions that “because it feels like oil and looks like it must be oil”, this is not how it works...Why??.... Because during the final stage of finishing commercial LPG treatment, the LPG undergoes a caustic treatment (sodium hydroxide) to remove ‘trace amounts’ of sulfur, then a water wash prior to commercial shipment.
    The possibility of an occasional slight caustic carryover exist (due to a process upset), and any sodium hydroxide carryover looks and feels exactly like oily lubricant, thus the immediate impulse to call it oil...You might try a piece of p/h test paper to confirm.
    Also, caustic is similar to acid because of it’s corrosiveness to components.
    3 tons
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
