ktmrfs
Apr 02, 2021Explorer III
unless you have a true rms voltmeter, the voltage reading from these old (and some newer) battery chargers w/o a battery hooked up is really of marginal use. The old ones used selinium rectifiers and no output filtering, that was the job of the battery. So the unloaded output voltage is NOT DC, nor is it a sine wave.
About all a DC or "peak responding sine wave 60Hz calibrated" voltmeter will tell you is that there is an output voltage.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
