Gdetrailer
May 18, 2021Explorer III
30sweeds wrote:
General opinion is you can't leave them hooked up 24-7 like a smart charger.In the auto mode,I can leave mine hooked up as long as I want as the charging rate drops to zero when the battery is fully charged.It will also charge up a stone dead battery.
Old school chargers were never meant to be left on a battery 24/7/365, they were a simple design that was supposed to charge a totally dead battery (like from leaving a door open or headlights on overnight) up to full enough to start your vehicle.
Simple design that just works and typically those chargers are pretty much bullet proof and a fair chance would even survive a EMP blast from a nuclear bomb..
As far as smart chargers, you are very lucky to have one that has a "auto mode", most smart chargers do not have that and require you to push a button to start charging. When charger believes the battery is charged, the unit shuts down and never turns back on unless you disconnect it and then connect and push the start button again..
Not to mention as been stated, most smart chargers will refuse to charge a battery that is considered "dead" as in below 10V..
Now if what you are calling a smart charger that has 5A or less capacity then you have not a smart charger but a battery "maintainer". Those units are like a mini three stage converter and will start charging even if battery is below 10V, they will also drop into "storage mode" to a float voltage of 13.2V when battery is full and they will switch to bulk mode (14.4V) as needed.
I have a 5A version like that that I keep on my backup gen but a "charger" it really isn't, it would take weeks to charge a totally dead battery with 5A of current larger than a lawn tractor battery..
Correct tools for the job makes things easier.
