23hotrodr's avatar
23hotrodr
Old automotive battery charger question
I have an approx. 40 year old 12/6 volt automotive battery charger. When set for 12 volts and not connected to a battery, it reads 12.81 volts. Set to 6 volts and not connected to a battery, it reads 8.1 volts. When I connect to a 12 volt battery, and set for 12 volts and battery fairly well charged I read about 16 volts and the battery starts boiling right away.
Does this seem normal? Should the difference of charger output boltage be that much different when connect to a battery?
Thanks for any info you can provide. -- Mick
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
