beemerphile1
Jul 01, 2020Explorer
Pressurized tanks used to be common in earlier RVs, I had some back in the past.
You may be able to retrofit the system using a modern demand pump. You will still need a way to fill the tank and will have to add a vent. If budget allows I would replace the old galvanized tank.
