KendallP's avatar
KendallP
Old Norcold Fridge - Died Suddenly
2-way fridge. Lights on the eyebrow don't light and there's no ignitor activity nor can I hear valves for LP and 120V also does not cool. There's proper DC voltage on either side of the 3A fuse. Hard to imagine the eyebrow rocker switch went out suddenly for both AC and DC and since I don't have a circuit board tester in my toolbox, I'm guessing I may be out of easy diagnostic options and my next move may be to see what a new board can do. Or am I wrong? (He waits for his cantankerous, adopted gramps, Mexicowanderer to gripe at him if he doesn't run every possible diagnostic at his disposal... and some that aren't.)
This is the one book I don't have in my packet from the original owners and I can't read the model number on the placard. It's an '86 Winnebago, so my research seems to point to an 8310 EG2 or 838 EG2 ("2" for 2 way, i.e. LP and 120V.) I don't know what the differences between these 2 are, but either model uses the same Dinosaur board. Below are some photos if anyone has knowledge enough to agree or disagree with this assessment.
If correct, it appears that the recall was performed as the board does not appear to be the original. These folks performed maintenance well before recommended intervals, so it would be reasonable to believe that they had the recall addressed as well. There are also little plastic buttons on the far outsides of the eybrow which is supposed to be another indication. AND... I don't see that there is AC power inside the eyebrow, which was supposed to be the fire hazard that caused the recall. Hope I'm right.
First photo is a shot of an original board from Dinosaur's page and below that... my current board. Then the rest of the unit in case any of you can recognize it that way...
  • You could see voltage but not have amperage because of a dirty/corroded terminal. I would power it down and remove and reinstall all the connectors to establish a new "bite". When you have the terminal off of each connection do a little tug test to be sure the crimp is good to the wire. Start at the panel for the main fuse
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 21, 2025
