Calicajun
Mar 27, 2018Explorer
In radio/TV talk an Omni directional antenna is known to be equally weak in all directions. Same is true for RV antennai, aiming an antenna is always better. That doesn't mean the omni antenna you are looking at won't work as well or even better than your current antenna.
Will the new antenna system have booster, is the new antenna (omni) larger (more gain) in size than the old antenna. Read or post the specs of both antennai to see which is better for you.
Another tip if possible when you change out the old antenna also replace the coax cable too. Coax cable goes bad after time, plus most manufactures don't put the best quality cable in their RV's.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
