S_Davis
Jun 13, 2019Explorer
MEXICOWANDERER wrote:
You nailed it :)
8-D batteries are indeed pickier than other jars. Tall jars are the least picky. Picky means per amp hour their CCA may be more but time to recharge may be a bit longer .It isn't enough to dissuade choice of BCI models.
Here is an AGM tip. If you can source a precision ammeter, float maintenance whole and fractions of an amp readings can offer valuable clues as to the condition of the battery. But measurements must be taken at the same ambient temperature. Same for a 12.234 digital voltmeter.
So it sounds like the 8Ds would be better for a large inverter.
